跳转到主内容
Xbox One controller introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10. This controller fixes many of the design flaws found on Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the Model 1914 controller.
136 个问题 查看全部
Left joystick continues outputting forward or back motion after flick
I have an Xbox One 1708 controller. It's worked great over the years, and I've taken good care of it. It lives in a pouch in my laptop bag when I'm not using it. It may have been dropped once or twice, but I've never noticed any issues after those few incidents.
After some months of not playing rocket league (all I use the controller for) I recently got into it again and noticed after I flicked the left stick up or down (forward / backward), It would continue inputting movement in that direction as if it was pinned there. This is only the case for up/down movements, left/right movements are fine. If I move the stick in the opposite direction of the ghost movement, it will respond to my control again.
What do you guys think? Does it just need a good cleaning or am I due for some repairs / a new controller?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Stick drift. You need to replace the stick module on the circuit board. Easy enough if you're confident soldering. If not a computer shop should be able to replace it.
这个答案有帮助吗?
得分 1
2条评论:
I'm great with soldering. I may need to get a finer tip for mine though as I don't think it's small enough for this task. Any recommendations on where to pick up some new joystick modules?
完成的
I buy mine from ebay normally
完成的
添加一条评论
添加你的答案
Paulo Mello 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 38
