跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
548 个问题 查看全部
Why it is showing service battery even the battery gives the good time
I bought a macbook pro mid 2012....battery is running fine means it give 3-4 hours backup.
but im facing the issue with that notification showing that service battery.
ok so at some point i saw my battery was 24 % but after a while it shows 35%....
i dont know whats the issue is or should i replace the battery...
Update (09/12/2022)
here is the screenshot of coconut battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Lets use a better tool, please download and run Coconut Battery and post your results.
https://www.coconut-flavour.com/coconutb...
完成的
添加一条评论
1个答案
最有帮助的答案
Sorry to say your battery is quite old! The batteries chemistry has a lifespan and its overshot that. You've been lucky the system is still working.
Hee's the needed part MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery and the guide to put it in 2012年中期视网膜屏Macbook Pro 15''电池替换教程
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery图片
产品
$79.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Entertainment House 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 25
