跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
780 个问题 查看全部
My PS3 disc is stuck, how can I get it ejected?
I got the dreaded YLLOD with a disc still inside.
Yes, I have seen the help here about the fan cycle. It doesn't work for me—it just goes to yellow. Is there any other way apart from dismantling my PS3?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 20
11条评论
This question was migrated from http://meta.ifixit.com/Answers.
完成的
I had to turn it upside-down, tilt it down, hold the power button and the eject power at the same time in order for it to give me my dvd. Pretty much put my PS3 into submission.
完成的
http://ccm.net/faq/4912-ps3-how-to-force...
It worked perfectly for me...... plug out the PS3 keep ur finger on the eject button and plug in ans switch on .......whammmm!!!!!! there come ur DVD ...out... its easy...
完成的
I've tried all of the above but it hasn't worked for me
Im wondering when i get thisYLod fixed. Am i able to Still keep the DVD once its repaired?Please respond ASAP
完成的
I too had the same problem with a stuck disc I tried all the techniques to remove the disc but I figured with my playstation having the ylod anyways I figured what more damage could I do by removing the blu ray drive and opening it myself be prepared if u decide to attempt this there are about a dozen or so screws holding everything together
完成的
显示更多的6条评论
添加一条评论
18个答案
最有帮助的答案
If you havent figured it out yet, this is what you do. Turn the main power switch off in the back. Next, hold down the eject button and turn the switch back on. The fan will run high and it will eject your disc. May have to do it a couple of times. Worked on the second try for me.
这个答案有帮助吗?
得分 21
13条评论:
thx that worked great
完成的
Hey man. 3 years later and this worked for me. I just registerd to say thx :-)
完成的
I tried don't work
完成的
thanks got my gran turismo 6 disk back out first try
完成的
How to eject jammed CD disc of PS3 Slim - Fast & Easy way with 1 hand !
https://www.youtube.com/watch?v=iStLmErG...
完成的
显示更多的8条评论
添加一条评论
If holding the eject button and pressing and HOLDING the power button till the power light is green does not eject the disc, It may be the drive is DUFF or just jammed for some reason.
THIS GUIDE should be your next option.
Pull the drive out and see if there is anything obvious.
PlayStation 3 Yellow Light of Death (YLOD) Fix Kit may also be worth consideration.
PlayStation 3 Yellow Light of Death (YLOD) Fix Kit图片
产品
$24.99
这个答案有帮助吗?
得分 3
2条评论:
How to eject jammed CD disc of PS3 Slim - Fast & Easy way with 1 hand ! https://www.youtube.com/watch?v=iStLmErG...
完成的
Thanks this worked
完成的
添加一条评论
sometimes manual and force eject don't work . I've made my own way of ejecting it . you get 2 discs and force them in to get the 3rd out just make sure bottom one doesnt go in more than top .
its worked every time. don't waste your money.
这个答案有帮助吗?
得分 2
1条评论:
My little one pushed 3 DVD's into PS3 and I did get all out by pushing in the 4th one. Thanks
完成的
添加一条评论
Definite fix.
Turn off system.
Hold eject bottom down and turn it back on.
This will put your disc back into PLSY position.
HERE'S THE TRICK THOUGH.
Hold another disc just slightly in the disc tray, you should bring up solid on the disc inside the system.
Hit the eject button, wait half a second and then take out the disc you're holding. It should hold the tray open long enough for the regular eject.
Should come out then.
I tried this 4 times before it worked.
这个答案有帮助吗?
得分 2
1条评论:
Worked first time cheers mate
完成的
添加一条评论
Turn off the PS3 by removing the power cord.
Put your finger on the Eject button and hold.
While keeping your finger on it, turn on the PS3.
Wait for 10 to 30 seconds (during this time, the fan will be louder than usual) and release.
Your game disc should be ejected.
You may have to do this a couple of times
这个答案有帮助吗?
得分 2
添加一条评论
I did what you said guy none of them works, i think i have a problem in my ps3 , so here's what i did i pressed eject button then entered edge of new CD game in case there's something not opening while ejecting Process & it's worked."
hey thanks btw (y)
这个答案有帮助吗?
得分 1
3条评论:
Best troubleshooting trick ever! My son was devastated when he realised his 2 year old sister had stuck multiple DVDs in, fan trick did nothing. Placing 1 disc in part way in and pressing eject got 2 discs to come out, pressing eject got a 3rd disc out. THANK YOU!!!
完成的
the ps3 he is useing is out of date
完成的
Probably a dead blu-ray drive.
完成的
添加一条评论
http://www.playstationlifestyle.net/2011...
这个答案有帮助吗?
得分 1
1条评论:
This method details a way that you can use a secret compartment. It's also detailed here: https://support.playstation.com/s/articl... -- it's the way that worked for me
完成的
添加一条评论
The most effective way to get your disc unjammed from the disc tray of a PS3 is to use a bar burrito card, a largely effective tool in maneuvering the disc out of the disc tray.
这个答案有帮助吗?
得分 1
添加一条评论
You should press both buttons at the same time, you will hear some beeps and hopefully it will spit out the disc.
这个答案有帮助吗?
得分 0
添加一条评论
The answer from MICHAELPALACIS(below) was absolutely spot on. I removed FOUR DVDS from the machine.
Thank You!
Sometimes manual and force eject doesn't work . I've made my own way of ejecting it: You get 2 discs and force them in to get the 3rd out. Just make sure bottom one doesn't go in more than top .
This worked every time. Don't waste your money.
这个答案有帮助吗?
得分 0
4条评论:
How to manually eject a disc from PS3 slim: http://youtu.be/C-lfUEUNIS8 I watched this video and was the only thing that helped for me
完成的
How can I ever get two additional discs in??
There seems to be something blocking it.
Btw; how can i be sure that there is a disc stuck in it? Maybe there's another problem just preventing me to insert a disc.
When I want to play the system says there's no disc..
完成的
I solved one part of teh matter. Dismantled the PS and part of the blueray player and managed to get the disc out.
However, now still I can't get a disc in anymore. there's a white pin or something blocking it.
Any ideas how to fix that?
Thanks!
完成的
I also have a white pin blocking my disc to be inserted in my console how do I fix this.
完成的
添加一条评论
swithch off the console unplug it. Again plug it in and before switching it on keep your finger on the power botton ( keep it there till your DVD is ejected) NOW SWITCH IT ON...the player will run in high speed and after a few seconds DVD will be ejected. Enjoy.....
这个答案有帮助吗?
得分 0
添加一条评论
On the underside of the playstation where the screw for hard drive is the cover is bigger and pops out leavening one hole with your hard drive screw and and anothef with no visable screws if you put your screwdriver in this hole and turn it will manually eject may need to turn upside down to get disk in right position worked for me when fan test would not unfortunately my son had also put 2p in it with the 3 stuck discs so I had to dismantle an yway
这个答案有帮助吗?
得分 0
添加一条评论
If you can see the disk use a tweasers to grab it then hit the eject button
这个答案有帮助吗?
得分 0
1条评论:
Be sure the tweezers do not conduct energy, or you could nuke the PS3 and yourself.
完成的
添加一条评论
Yes, will let you know which one is successful
Update (03/05/2017)
I tried a couple ideas, what worked for me was turning the switch off in the back. Holding the power and eject same time and switching the back power on again.
这个答案有帮助吗?
得分 0
添加一条评论
Yes because you can open the ps3 and just by using a screw driver, and u can see everything in it
这个答案有帮助吗?
得分 0
添加一条评论
Don't they have the screw on the bottom for ejecting the disc I remember this when I used to fix the YLOD.
这个答案有帮助吗?
得分 0
添加一条评论
Press and hold the power and eject button at the same time, after confirming the blu-ray drive is not at fault. If this doesn’t work, replace your fan and try again.
Hope this helped. This is what I did for my blinking red light problem, and I finally have my Red Dead Redemption: Undead Nightmare disk back.
这个答案有帮助吗?
得分 0
添加一条评论
Yes the screws on the bottom undo all of them and the the disk drive has screws to and undo them to then it should be undone enough that you can just grab it out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ronan 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 106
过去 30 天: 448
总计 179,055
