跳转到主内容
加入维修社区 - 创建账户
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Screen doesn't work right when front camera is installed.
A really long time ago, I had a iPhone 5 as my phone. The battery caused the screen to come up off of the housing. This was all before I started doing iPhone repairs. I took it into a repair shop, and they replaced the battery, but the screen was still sticking up some, so we asked if they could fix it, and the guy tried to glue it together. The glue leaked into the LCD and messed the screen up, so they said they would replace the screen. Once that was done, the screen wasn't working right (glitchy, would tap randomly, wouldn't respond to touch.) We got them to replace it again, but the same things kept happening. We got frustrated and just gave up.
Now that I do a considerable amount of iPhone repairs, I have tampered with the phone quite a bit. I found that the screen works perfectly fine when front camera/speaker assembly is not attached. Does anyone know why this is happening and how I can fix it if I wanted too? I have tried a lot of different screens as well...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论:
Anyone have any tips on what the issue might be?
完成的
@cooltool - Can you post a picture of the Camera connector on the logic board?
完成的
@beanman56 I added it to the post.
完成的
Any thoughts?
完成的
添加一条评论
1个答案
I think the Repair store Had a screw loose!
But Try using a Q-tip and some Isopropyl Alcohol, And scrub the Camera connector on the camera and on the logic board, If that doesn't work Or you don't mind just not having the camera.
Part: iPhone 5 Front Camera and Sensor Cable
Guide: iPhone 5前摄像头及排线替换
Replace a front camera and sensor cable compatible with the iPhone 5 smartphone. Includes the front facing camera, secondary microphone, ambient light and proximity sensors. Part #821-1449-A, 821-1449.图片
产品
$19.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Crosby Grim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 154
