跳转到主内容
Repair guides and documentation for the Google Pixel 5a with 5G smartphone. Released in August 2021.
How do I best apply the precut adhesive?
First timer, looking for any best practices. Thx
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hi
The best way of applying adhesive is usualy be cleaning the surface first
Then lining it up and applying it
For the pre cut adhesive I find that if you peel the protective film off to about halfway then get a plastic pry tool and use it to press the adhesive into place
Once you are confident that it’s stuck down good I would peel the other protective film off and adhere when you want to it
Here’s a video on it!
https://m.youtube.com/watch?v=AsYamvF8Y1...
If you skip to the 1min mark that’s when the explanation starts
This video isn’t for your phone but it’s the same process across just about everything
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Thomas H Chapin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 324
