跳转到主内容
Xbox Series X 是微软公司次时代4K游戏主机。2020年11月10日,Xbox Series X与其配套主机Xbox Series S一起发布。
42 个问题 查看全部
What hardware would cause stuttering?
I’ve noticed tiny stutters when moving the screen and frame drops on certain games on the Series X. If it was due to a faulty component, what component might that be? SSD? CPU/GPU? And where would you get such replacement parts? Could it be just the game itself? Could it also just be a faulty console update?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Nobody knows, Xbox is a fully encrypted and un-debuggable unit in retail mode.
Are you sure it is not just bad game coding? Does the issue happens on the same game with every Xbox?
这个答案有帮助吗?
得分 2
2条评论:
I don’t have a spare Xbox Series X to try. Some games run better than others. However there are issues with some games stuttering when you enter a new area which leads me to believe it’s an SSD problem. I replaced thermal paste so it can’t be an over heating issue. Not sure as well if it’s solely due to the fact I’m on 60Hz instead of 120Hz.
完成的
@kain05 Still sounds like expected behavior to me.
完成的
添加一条评论
添加你的答案
Kane 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 249
