跳转到主内容
Early 2011 MacBook Pro has prohibitory sign on boot after SSD upgrade
This problem has been happening ever since I installed this new SSD.
I recently bought a Lexar NS100 256GB SSD for my MacBook Pro, as the HDD inside was painfully slow in macOS. I received it and as soon as I got it in, I decided to install Mac OS X Lion, just to see how fast it was. After install, it booted just fine with no problems at all. Apps opened quickly and swiftly. So, I decided to run Internet Recovery on High Sierra. I formatted the drive twice before installing it. As soon as it restarted, I got a prohibitory symbol. It would flicker between the Apple logo and the symbol, sometimes booting into macOS fine after. But, this problem has been noticeable on Windows as well, with the OS refusing to boot until I restart a couple of times. Other people online who have had this issue seemed like it’s the hard drive cable. But it seems to be in pristine condition (that might be because my eyes are kinda bad too). I have another laptop to try the SSD in, but I just want to make sure that this is the confirmed problem before I spend my money on a new cable. Here’s a video of the laptop going to the prohibitory sign, then booting completely fine after.
Update (09/01/2022)
@danj
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
And so @CGamez? Was the problem solved by changing the HD SATA cable?
完成的
添加一条评论
1个答案
最有帮助的答案
There's two things needed here to over come this first is to leverage the Startup Manager to select the boot volume.
Reference: Mac startup key combinations
That will allow the system to boot up. Then open your Preferences > Startup Disk so you can set it permanently. That should do it!
这个答案有帮助吗?
得分 1
20条评论:
I’m not having issues with not being able to boot into the correct OS, I’m having issues with both OSes not being able to boot correctly. It should boot without problem but usually requires multiple restarts.
完成的
@CGamez - Sorry the way you titled the question is what I was focused on as the video you posted is damaged.
You'll need to do two things! Install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片 So we can make sure the battery and the charging logic is working correctly.
I would also run the onboard diagnostics to see if something pops within it. Restart your system and press the D key. let us know what the errors are
完成的
@danj Ok, will do. Thank you.
完成的
@CGamez - The batteries age is long in the tooth! While the cycle count is just about 3/4 quarters used. So depending on your plans its time to look at replacing it soon. MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery and here's the guide MacBook Pro 13" Unibody 早期 2011 电池更换
完成的
I mean, I just wouldn’t think it’s the battery because I normally use the laptop on its cord most of time. I barely use it on battery charge, because of the low battery time.
完成的
显示更多的15条评论
添加一条评论
添加你的答案
CGamez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 523
