跳转到主内容
iPhone 13 mini 于 2021 年 9 月 24 日发布,它是 Apple iPhone 13 的缩小版,也是第二款的迷你 iPhone。 iPhone 13 mini 具有 5.4 英寸 OLED屏幕、A15 仿生处理器和后置双摄像头。
22 个问题 查看全部
How risky is it to replace iPhone 13 mini back glass
Just wanna know might be doing a replacement
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi
This repair is only risky if you don’t know what you are doing!
This repair is safe as long as you do the following:
-fully remove all components from the housing to prevent damage
-use the correct equipment EG:pry tool and hot air station or laser
-cover and protect your camera lenses
-Be careful and take your take your time as this repair isn’t easy
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 4
7条评论:
Hi also just wanna know what glue to use putting the new back glass on
完成的
@Pizzaconnor 11
I would use some form of liquid adhesive that’s strong:-)
完成的
Any specific glues
完成的
@Pizzaconnor 11
I have heard that B7000 is good for it:-)
完成的
Ok thank you
完成的
显示更多的2条评论
添加一条评论
After using a laser to remove a back glass there’s not a cat in hells chance I’d attempt it with hot air. UNLESS it’s been replaced before. Don’t bother watching YouTube videos as it’s not the original glass they’re removing as they are made to look easy. (Hence phones getting damaged by people thinking it’s easy) As said before, if you are going to try it then go easy and don’t force anything. You’d be better having a punch for around the camera lenses and a set of replacement mag safe magnets as they will come off and probably pull some coils off the wireless charger too. You might also rip the cable for the rear flash too.
Not being negative or trying to put you off. Just being honest about what could happen.
Good luck with it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Pizzaconnor 11 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 70
过去 30 天: 303
总计 2,405
