How do you check the transmission fluid?
There has to be a way to check my own transmission fluid on a 2015 Murano SV without taking it to the dealer or a mechanic.
@skweek1 dang that is a beast. Check on here under step 3
"The dipstick is not like the oil dipstick, there is no stick, so you won't be able to check the level.
To remove it, you will need a long skinny flat head screw driver. There is a tab on the dipstick, you need to insert the screwdriver to move the tap while pulling up on the dipstick."
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 49
总计 1,172
