跳转到主内容
Car shut off while coming to a stop.
Everything was put in new. 02 sensors, mas air flow sensor. Everything. But code stated 02sensor bank 1. Plz help thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Does the vehicle start again when you let off the brake?
完成的
No. The car shut completely off and I am able to turn it back on.
完成的
添加一条评论
2个答案
If your car is dying completely when coming to a stop a common cause is the gas to air mixture is too rich meaning your engine is not getting air. Try to locate the Air filter in the engine bay of your vehicle and spray it out with an air compressor or better yet just replace the filter.
这个答案有帮助吗?
得分 0
2条评论:
thank you for the response. I have change everything but for some reason i keep getting code p0131. 02 sensor was changed and nothing
完成的
If you changed the 02 sensor then you may want to check the wiring for the sensor. If you find no faults with that then there is the rare chance that the new sensor you bought is faulty, it happens.
完成的
添加一条评论
Checking the alternator's output could be an excellent first step in troubleshooting this issue. If the car still shuts off while starting and idling, then check 5fnyf6h53mb042819 pilot exl 2021 vin honda for loose connections or corrosion on the battery terminals or the battery itself. Your vehicle may have developed an electrical problem that could shut it off while you're driving.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hunter K 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 200
