My 07 suburbans rpm fluctuate when I am at a stop.
When my 07 suburban is at a stop the rpm fluctuate and the truck shake a little. If anyone has any suggestions please let me know.
My son's Cadillac Deville had similar symptoms and I ended up tracing it down the the Idle Air Control (IAC) valve. You might check that to see if it's the problem. Here's a page that should help.
Symptoms of a Bad Idle Air Control Valve - In The Garage with CarParts.com
这个答案有帮助吗?
My older suburban did the exact same thing. New plugs n wires fixed it right up.
这个答案有帮助吗?
RPM Fluctuation is a common side effect of worn out spark plugs. You can try to replace these yourself or hire an Mechanic.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 27
总计 476
