跳转到主内容
Furby was a popular electronic robotic toy resembling a hamster/owl-like creature which went through a period of being a "must-have" toy following its launch in the holiday season of 1998, with continual sales until 2000. Furbies sold 1.8 million units in 1998, 14 million units in 1999, and altogether in its three years of original production, Furbies sold over 40 million units.
85 个问题 查看全部
My Furbies won't move and they will turn off after a while
(I'm Italian so sorry for my grammar)
I have 4 furbies:
My 1999 one works perfectly fine, while my other 3 don't. They turn on but they don't move and they turn off after a while.
Could you help me find a solution, please? I'm very attached to these frubies since they were my childhood and it's sad seeing them like this.
Thank you
Edit: now the furby boom does this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Since you reset it, changed batteries, hard reset it and it still doesn't work this means there is something wrong with the motor. I have had 2 furbys that have done this before, The motor will sadly need to be replaced.
The small 6V brushless DC motor needs replacing. Here’s a guide that may help: Hasbro furby 2012 DC Motor Replacement
You could spin/jumpstart the motor or lubricate it. You can replace it with one from a PC DVD reader (this is the door opener motor). Shaft is smaller but it's ok, diameter is good. You need a solder iron as well to replace electronic part from DC motor. Once you get the 6V DC motor, you’ll need to solder it on the pre-existing motor wires....
I’m hoping this video I made, will help: https://youtu.be/UteznTOUegE
Also in one of your comments you say that the 6V Brushless dc motor makes all the wheels spin, but for some reason the furby still won't move. Maybe you could try wd40 lubricant on gears. Sometimes it gets stuck. If the gears/wheels are spinning then they may be out of place, and therefore need to be adjusted to make your furby move again.
It appears in the 2 videos that the lcd lights work which is good.
In the last video of your furby boom, the furby started doing the reset dance when talking. I have had 2 furbys that have done this before, after 1-2 weeks, they stop moving completely and the motor burns out. Since it moves up and down, then shutting off the motor is going in and out and will sadly need to be replaced.
If you would like you can always contact me at Oliviarepairs@gmail.com I will be able to walk through the process with you, but more in depth. I hope this helps! Thanks!
italiano version:
Dal momento che lo hai resettato, hai cambiato le batterie, l'hai resettato a fondo e continua a non funzionare, significa che c'è qualcosa che non va nel motore. Ho avuto 2 furby che l'hanno già fatto, il motore dovrà purtroppo essere sostituito.
Il piccolo motore CC senza spazzole da 6 V deve essere sostituito. Ecco una guida che può aiutare: Hasbro furby 2012 DC Motor Replacement
Potresti far girare / far ripartire il motore o lubrificarlo. Puoi sostituirlo con uno da un lettore DVD per PC (questo è il motore dell'apriporta). L'albero è più piccolo ma va bene, il diametro è buono. È necessario anche un saldatore per sostituire la parte elettronica del motore CC. Una volta ottenuto il motore a 6 V CC, dovrai saldarlo sui fili del motore preesistenti....
Spero che questo video che ho realizzato possa essere d'aiuto: https://youtu.be/UteznTOUegE
Inoltre in uno dei tuoi commenti dici che il motore 6V Brushless dc fa girare tutte le ruote, ma per qualche motivo il furby continua a non muoversi. Forse potresti provare il lubrificante wd40 sugli ingranaggi. A volte si blocca. Se gli ingranaggi/le ruote girano, potrebbero essere fuori posto e quindi devono essere regolati per far muovere di nuovo il tuo furby.
Sembra nei 2 video che le luci lcd funzionino, il che è buono.
Nell'ultimo video del tuo furby boom, il furby ha iniziato a fare la danza del ripristino quando parlava. Ho avuto 2 furby che l'hanno fatto prima, dopo 1-2 settimane, smettono di muoversi completamente e il motore si brucia. Dal momento che si muove su e giù, lo spegnimento del motore entra ed esce e purtroppo dovrà essere sostituito.
Se vuoi puoi sempre contattarmi a Oliviarepairs@gmail.com Sarò in grado di seguire il processo con te, ma in modo più approfondito. Spero che aiuti! Non sono molto bravo in italiano. Grazie!
这个答案有帮助吗?
得分 2
添加一条评论
ENGLISH
Hi
I don’t actually work on furbys but I have seen thing like this happen to other things
I would check where the battery’s go in as it could be corrosion or rust where a battery could have potentially leaked which would cause issues
If this is a issue I would clean the corrosion with some isopropyl alcohol
Hopefully this helps
Any questions please ask
ITALIANO
questa è una traduzione, mi scuso per eventuali errori
Ciao
In realtà non lavoro sui furby, ma ho visto cose del genere succedere ad altre cose
Controllerei dove entra la batteria in quanto potrebbe essere corrosione o ruggine in cui una batteria potrebbe essere potenzialmente fuoriuscita che causerebbe problemi
Se questo è un problema, pulirei la corrosione con dell'alcool isopropilico
Speriamo che questo aiuti
Qualsiasi domanda si prega di chiedere
Grazie:-)
这个答案有帮助吗?
得分 1
7条评论:
i just looked to see if there was corrosion and there wasn't any. I just looked it up and apparently there's some problem with the 6V Motor and i have to replace it. only problem is that i don't know how to do it. Thanks anyway.
完成的
@Mattia Gertrudino
I would try to find a video on YouTube
These usualy a disassemble guide to follow along with:-)
ITALIANO
Proverò a cercare un video su YouTube
Questi di solito una guida allo smontaggio da seguire insieme a :-)
完成的
Ok, Thank you for helping me so much
完成的
@Mattia Gertrudino
Your most welcome:-)
Il vostro benvenuto:-)
完成的
Nice toys, it takes me back, try a good clean of internals... I use contact cleaner g-20 or r-10 for pcb and battery socket, after that use some wd40silicone on internal mecatronic parts(including motor). Put new accu in and test toy.
完成的
显示更多的2条评论
添加一条评论
Hit the back of the furby while new batteries are in it may take a while
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mattia Gertrudino 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 51
总计 927
