跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Will it work without a blu-ray drive?
A friend has a console which was broken due to bad soldering on the chips and was stored somewhere.
Then a bright fellow decided he needed the motors on the bluray drive and has thrown everything else on the trash.
Now I think I've made the console bask to working shape, but since I have no drive, I can't figure out if it needs the drive to really work.
It currently powers up and down as it should, but I get no video at all.
If you could test on yours, just disconnect the flat cable and the white power cable. Let me know if you get image.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 1
评论:
You should get an image. Try a different video cable, also attaching a controller to it. What ever you do don't let it update like that.
完成的
As much as I apreciate all answers so far, no one has done what I humble asked for.
So, until someone tries it, I won't validate any answer.
完成的
Luis Correia, I do not think that this is a humble request. Nobody is going to tear their console apart and disconnect a cable, to answer your question. The goal on here is to assist others, not to get validated answers, so you are not harming anyone by not validating. I do wish you the best of luck.
完成的
I have a ps3 that my dickhead brother had decided to throw onto the tile floor everything but the blue ray drive works I have removed the blue ray drive and can still use everything but the discs
完成的
I know it's been like 5 year but I tried it now, it will turn on and all but if have multiman or webman (to play your backups) it will just freeze and show you a black screen. Anything else seems to work
完成的
显示更多的1条评论
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
10个回答
已选择的解决方案
Luis,
I don't have a console to test with myself, but I searched around the net and the consensus is that the PS3 will work without the BDR installed. You do however need to have the driver board installed.
这个答案有帮助吗?
得分 2
评论:
Yes, I am now aware that the console must be 'married' with its blu-ray drive.
But I still want to know if it produces any image without it connected.
As simple as that!
完成的
添加一条评论
Wish I could help, but mine doesn't even power up or down. Have you tried connecting the RCA cables and booting in Safe Mode? That would tell you if the video is coming through your video cable or not.
这个答案有帮助吗?
得分 0
添加一条评论
Has a ps3 bluray drive, problems solved.
这个答案有帮助吗?
得分 0
评论:
the optical drive is not related to the question asked.
完成的
添加一条评论
Have two ps3's..one up on the repair agenda, so thought why not. It works without a blue ray drive, video 'n all.
But if you want to fix the problem of not having a blue ray drive, visit ebay for some cheap replacements.
Might add also, if you press and hold the power on button untill you hear a second beep it should search for alternative videosource, might be why you're not getting any video at all.
这个答案有帮助吗?
得分 0
评论:
Thank you David.
With your feedback, I can now continue to search for the root cause of the problem, as the bluray drive not existing is not a problem.
完成的
添加一条评论
My fat model ps3 works without a blu ray drive. I'm currently repairing it.
这个答案有帮助吗?
得分 0
添加一条评论
ps3 works without blu ray drive ,shows xmb and you can play with menu icons but nothing else
这个答案有帮助吗?
得分 0
添加一条评论
CECHG-03 works and plays games from HDD without blu-ray drive perfectly :D
这个答案有帮助吗?
得分 0
添加一条评论
ribbon cable from bluray to motherbord if its not good thats what happende im trying to find a work around will let u know if i find something out
这个答案有帮助吗?
得分 0
评论:
I'm not 100% sure the guy who posted this 6 years ago will still require your input.
完成的
添加一条评论
if your on a cfw and CEX ++https://www.psxhax.com/threads/bobbydown... Overflow 4.82 v5 cobra cex NoBd edition lets you update with out a blueray drive and its the latest firmware 4.82
这个答案有帮助吗?
得分 0
添加一条评论
Hi I too have this problem. In my case wanted to make a small cluster and shockingly this one is linux capable. Fortunately the original owner broke it just before the new fw came out so may try it with just pcb connected to see what it does.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luis Correia 将永远感激不已
浏览统计数据:
过去的24小时: 4
过去的7天: 37
过去的30天: 182
总计 14,734
