跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 个问题 查看全部
japanese region 3ds how do I change to english
have a Nintendo 3ds bought in japan it however is in Japanese, how do i switch it into English?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 20
5条评论
That Japanese 3ds is still useable and you can play online with any games you want after hacking it, you just need to downgrade the firmware, here are keywords to get you started: 3dsiso.com , cia files, gbatemp.net , homebrew channel, downgrade firmware from 10.3 to 9.2, memchunkshax, and rxtools/custom firmware
完成的
how do i hack it?
完成的
watch a tutorial on luma3ds.
完成的
Look up this on YouTube Changing the 3DS REGION - UPDATED GUIDE 2020
完成的
Look up Changing the 3DS REGION - UPDATED GUIDE 2020 on YouTube
完成的
添加一条评论
8个答案
已选择的解决方案
You cant change it, and also, you cannot transfer data between a Japanese 3DS and a English 3DS. Gamestop CANNOT do that either. Plus, data saved on the SD Card of the Japanese 3DS also cannot be transferred to ANY 3DS what so ever, besides the music and pictures you put on it yourself.
这个答案有帮助吗?
得分 5
添加一条评论
You Can't Change It. But I would suggest changing it at gamestop and get all the memory you had on the japanese one transfered to the english one. I Hope this helps
这个答案有帮助吗?
得分 1
6条评论:
Why can't you change it? My daughter bought a new 3DS off of Amazon. Her old one is broken. It didn't say it was from Japan. We didn't know until it arrived. What are we supposed to do now? We've had bad luck trying to ship things back overseas before. That puts her out over $!30 bucks. She can't do anything on it.
完成的
Her games won't work on it, either.
完成的
Her games dont work>>>?
完成的
Of course her games don't work. The 3ds is region-locked. You have a Japanese 3ds trying to play NA games on it. I'm sorry that you guys lost money on this, HOWEVER, there is a market stateside for Japanese 3DS's. I can almost guarantee you that she won't get 130 for it. But if you can't get it returned one place I can recommend is posting on reddit.com/r/MonsterHunter . Monster Hunter Cross came out and people who couldn't get CFW to work or won't install CFW (Custom FirmWare) may buy it off you.
完成的
You can hack and downgrade the firmware, read my previous answers to this post. You better hurry because nintendo will release 10.4 firmware soon to patch the new exploits
完成的
显示更多的1条评论
添加一条评论
If you're willing, and have the tools and know-how, you could probably just swap the motherboards of a Japanese 3DS with that of any other region's. I can't swear it'll work, but I did the very same with my old DSi. Like the 3DS, it's region locked too. It works just fine. Plus, you get to keep any previously installed software and whatnot.
这个答案有帮助吗?
得分 1
2条评论:
Memory is stored on the Mother board, and if you change the motherboard, that memory is gone. Also, you WONT be able to use any software thats on the sd card that was from the old motherboard due to anti-copying precautions.
完成的
Don't know why I care, but I can say for a fact that it DOES work. I've swapped several 3DS motherboards over the years. They all work fine. With these recent "New Nintendo 3DS and New Nintendo 3DS XL/LL" counsels, its a whole new ball game. If you want one of those, go with your own country. That's my opinion. The faceplates are compatible with any regions system (excluding XL/LL).
完成的
添加一条评论
Trying a CFW (Custom Firmware) might be an option. I don't know how far the mod scene has come with the Japanese version though. You'll have to do a great deal of digging on Google.
这个答案有帮助吗?
得分 1
1条评论:
It works! https://3ds.hacks.guide/ is the place and also going on the nintendo homebrew discord server. barely any digging required.
完成的
添加一条评论
I was able to change area and version by Good Mode
这个答案有帮助吗?
得分 1
4条评论:
How did you change it?
完成的
I mean what's a Good Mode?
完成的
Yes please help; what is good mode bc the Japanese consoles are so much cheaper. As long as I can change it to english I would love to purchase all my games and stuff from Japan bc it's much cheaper than the U.S.
完成的
I think he's talking about GodMode9, a home brew firmware that the folks over at nintendo homebrew made to let you do all sorts of things that nintendo doesn't let you do normally. give it a google!
完成的
添加一条评论
So, actually you can change the region, and play region locked games on your Japanese 3ds. However you’re going to have to void your warranty (which…. at this point you’re gonna buy it used so who cares?) go look for nintendo homebrew https://3ds.hacks.guide/ (there’s the link) and the guys in the discord server will walk you through anything you don’t understand! very nice community.
这个答案有帮助吗?
得分 1
2条评论:
Where can I find this Nintendo homebrew discord server?
完成的
It's in the link that he posted.
It says something about if you have questions join the discord, which discord is hyperlinked.
完成的
添加一条评论
You can't change it. Also, you can't modify it to English. Even games for English or any other region cannot be play for Japanese. You can only play japanese version of games.
这个答案有帮助吗?
得分 0
添加一条评论
I am will to use the Japanese 3ds games > only need to change lanuage to english. Can I change the lanuage to English for a region locked Japanese 3ds?
这个答案有帮助吗?
得分 0
1条评论:
not without CFW. use 3ds.hacks.guide to install b9s and luma, then follow the region changing guide to switch to another region
完成的
添加一条评论
添加你的答案
navalchck 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 39
过去 30 天: 159
总计 173,366
