跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
iPod Disabled - Problem is that the hold button is faulty!
As tittle says, I have a disabled iPod touch, I know I can restore it on itunes but the problem is that the hold button is faulty so I can't put in restore mode...
Tried replacing the button with a new one but the problem remains the same. No response from hold button.
Is there any other way to put the ipod in recovery mode?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The "z" spring the hold button makes contact with probably needs to be slightly re-stretched. Pull up on it a little to get it back in shape. Be careful not too much because the spring will pop off. If you don't want to do that then while the ipod digitizer is off the hold button "press" can be simulated by shorting with a wire between the ipod case and the spring. Unless you have three hands then a friend may come in handy for the last part.
这个答案有帮助吗?
得分 1
6条评论:
Thanks for you reply. When I mentioned that I've tried another button I mean a new complete circuit with hold +volume buttons. Only the hold doesn't work although mechanically it seems fine.
完成的
The diagram for the home button is like this: http://imageshack.us/photo/my-images/215...
In that image when the digitizer is in place 1 and 2 are in contact with each other and 3 and 4 are in contact with each other. The button just completes the final connection. I'm thinking that your spring (#4) is not making contact with (#3) and the spring needs to be cleaned or stretched a little.
完成的
Thaks for the info but that's the home button, the one I have faulty is the hold button. Or am I missing something here?
完成的
Not missing anything... I totally misread that "hold" button. I'm afraid I can't come up with a solution other than replace the cable, which you already did.
完成的
I've found a software which takes the touch into and out of recovery mode with just a mouse click but to work properly I would need to install an additional software called libsub, problem is that the feeback from people who've installed this is horrible. I'm a bit tempted to try it though...
完成的
显示更多的1条评论
添加一条评论
添加你的答案
BOL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 608
