The graphics card fan is rotating but no display whalt to do?
Not display in monitor
Hi
If it’s not displaying make sure of these things
You have the correct power cables plugged in and have a power supply power full enough to handle it
Make sure that the pcie slot isn’t faulty by trying another GPU
Try taking the cooler off (usually 4screws on the back,make sure to take them out slowly,quarter turn on each one at a time to apply even pressure)and checking for and blown components or discolouration on the pcb
Make sure your video input pots don’t have any debris
Make sure your drivers are up to date as well as your OS
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
I have a E Geforce 8800gts on W11 and I don't know where to get the drivers
Is it a prebuilt computer or A custom one?
If it’s prebuilt you will probably find them on the manufacturers website
Or if it’s custom you will find them on Nvidea’s website:-)
@hellomacos custom but there drivers only support W10
Have you tried installing them?
@hellomacos yep
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 264
