跳转到主内容
Windproof and water-resistant, the Patagonia Nano Puff ® Jacket is made with warm, incredibly lightweight, highly-compressible insulation, and is ideal as either an insulating layer or outerwear.
29 个问题 查看全部
How to remove sticker residue from a Nano Puff Jacket?
A sticker was put on the Patagonia Nano jacket and now the glue residue is on it. Is there a way to get the residue off?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Dry cleaners should know otherwise try contacting Patagonia. Another option is considering the various solvents like glue-be-gone, alcohol, acetone, etc. The risk of incorrect solvent use may be staining, dissolving material, and oily residue.
这个答案有帮助吗?
得分 0
添加一条评论
Isopropyl Alcohol works great. I would not use any Petroleum based products like Goo Gone, the oil will stain.
Using Isopropyl Alcohol, a clean rag, a little muscle and patience you can remove adhesive residue. If it is from Duct Tape be prepared to put some effort into it, but you can remove that adhesive as well.
这个答案有帮助吗?
得分 0
添加一条评论
Use a rubber eraser tool used for removing rubber cement. It will grab onto the adhesive and pull it off. It may take a bit of time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
twentyfivefrisbee 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 101
总计 1,442
