跳转到主内容
宏碁 Chromebooks 维修指南。
242 个问题 查看全部
Acer 11 C731 replaced charger port wire and still won't charge, help
Replaced Charger port on Acer 11 c731 and charger light won't go on or charge. Is there anything else I can do or charge this chromebook a different way?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
did you try a different charger ?
完成的
Yes multiple chargers and even tried multiple new ports
完成的
@Stephanie Adamietz then its more than likely an issue with the motherboard
完成的
Thank you we decided to just replace these and keep them for parts.
完成的
添加一条评论
3个答案
已选择的解决方案
In my experience, if replacing your DC-In Jack did not resolve your issues, there is most likely an issue with your machines motherboard, or battery.
In most cases, it may not be worth putting a lot more effort into fixing this issue, as the motherboard generally outweighs the cost of a new machine entirely.
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
If you know how to use a DMM and how to read schematics then maybe consider buying them. Here's a supplier
这个答案有帮助吗?
得分 1
添加一条评论
Test the fuse near the port on the board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephanie Adamietz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 89
