Smd blue ligts indicator
I broke my ps4 smd blue led light Indicator so how can i resolder that and which type to buy please guide me i need my blue light Indicator back
You can resolder it. But make sure your soldering iron gets hot enough to melt solder. You have good quality solder, and you use smaller soldering tip.
这个答案有帮助吗?
@peace7777777 and Mohammed Sultan yes you can solder it back on. Your solder pads look good. Get your self a decent soldering iron some solder (I prefer leaded 60/40 solder) and some good flux. Tin the solder pads and re-solder the LED.
If you have never soldered before, find some old circuit boards and keep practicing first. It is a bit of an art and requires practice.
As for the LED that would be a SMD LED and most likely a 0603 size. If you measure from contact to contact we can be exact.
led solder past got u dude pretty common problem
heres an exscample of soder past u will need a heat gun
How to Use Solder Paste (Soldering with solder paste & heat gun) - YouTube
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 96
