跳转到主内容
This is an older equipment line from Saeco. All are labeled Sup 018. (Badge on the bottom). They were later sold under the name Spidem Trevi
13 个问题 查看全部
Saeco Vienna grinds beans but doesn't stop grinding or proceed to brew
First my Saeco is NOT a Sup 018, just a Vienna probably because it is 20+ yrs old. I have determined the grounds are not being dumped from the collector into the brew group because the solenoid is not being activated. However I do not know whether the solenoid is bad or whatever determines there are enough grounds has failed.
What triggers the 'dump-the-shot' action?? is my basic question.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
There is a microswitch that sends a signal to the circuit board which starts the doser solenoid and the brewing cycle. Could just require dismantling and cleaning or new switch. Worst case new circuit board. Unlikely it is the solenoid Most likely needs cleaning.
这个答案有帮助吗?
得分 0
添加一条评论
Google for "Saeco Vienna Testmode". This will help determining the issue, e.g. this video. I see two possibilities: the microswitch of the grind chamber, as mentioned above, hopefully a cleaning ist sufficient, maybe a replacement of the switch. You will find the chamber following the outlet of the ginder.
Or worse: a faulty PCB, in this case a replacement is an option. Much cheaper is the replacement of some parts on the PCB, there are repairkits. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ken Sharples 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 74
