跳转到主内容
加入维修社区 - 创建账户
The PSP 3000 was released in the U.S. on the 15th of October 2008.
The X button isn't working
I just excavated my PSP 3001. I'm currently cleaning it, but when I finished making sure all the grime was gone, the X button started not to function. I cleaned the sensors, and every button except for X has a little delay here and there, but they work. Is there something I'm missing or did I do irreplaceable damage?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What do you mean, excavated?
完成的
The x button is working by itself
完成的
添加一条评论
2个答案
What I would do is get a replacement x, square, circle, triangle pad (the thing that you cleaned). They’re fairly cheap on Amazon.
这个答案有帮助吗?
得分 0
添加一条评论
A potential solution exists for the issue you're experiencing. On the right pad, where the "O" button is situated, you'll find a small bent tab connecting the upper and lower parts of the pad. Essentially, when these connectors make contact, it registers as a click, corresponding to the button you're pressing.
It's possible that the X button is consistently registering as pressed. To address this, consider placing a narrow strip of paper next to the X button, avoiding the rounded dot in the middle but positioning it directly adjacent. This adjustment should disrupt the constant connection, allowing the button to activate only when pressure is applied, thus resolving the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Patrick McCarthy 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 72
总计 2,121
