My freezer is hot 68 degrees
My freezer is hot and has stopped freezing. I checked the evap coils and there is no frost on them.
I have a Samsung RSG257AARS twin cool refrigerator
Update (07/30/2022)
plugged refrigerator in to the power. Let it start up.
i already had one line connect to a puncture valve in back or refrigerator and to my center of manifold gauge, I had the blue and red knobs closed off. On the blue side of my manifold gauge I had a line connect to it running to can of r-134 that was also closed. One the refrigerator startup I wait 10 mins and open up the blue knob of my manifold gauges. And got that reading I did get this error code today.
2条评论
Review your warranty. Electronics may be warranted separately from the sealed refrigeration system(s). Dual systems complicates diagnosing and may require trained techs to diagnose.
由 F Dryer 完成的
I think your connections to manifold gauges are incorrect. The center line (yellow) connects to either a vacuum pump or refrigerant canister. Blue line connects to low side service valve, red line connects to high side service valve. Gauge valves are closed to measure system pressures. Lines are purged before measurements.
由 F Dryer 完成的
