跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
244 个问题 查看全部
Upgrading through motherboard swap?
Hi I have a base mode MacBook pro 2016 15 inch with 2.6 i7 256 storage etc
I was thinking about upgrading it to the 2.9ghz i7 1TB storage
I found a local seller with said 2.9/1tb mobo for this model for a good price and it comes with touch id as well my question is
Can I actually do that just swap in a higher-end motherboard for the same model as long as i have its paired touchid or will there be some other issues that im unaware of?
Also would a 2017 mobo work in 2016 one ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Before you start I would first make sure you have the latest macOS and updates applied then backup your stuff onto an external drive using TimeMachine. Once done go into FindMy and remove your system from your group. And disable any protection you have on the drive.
Last step here is reformat your systems drive and install a clean copy of macOS. I would recommend you boot up under an external bootable drive (setup just for this task) to achieve this so there is no fingerprints of yours on the system.
Now the fun stuff! Remove the logic board and be very careful with the power button/TouchID ribbon cable as its very easy to damage. Use care as its easy to snag the other cables when you put in the replacement logic board. Using the external bootable drive boot up and format and install a clean copy of macOS here we want to be sure nothing is on the drive (i.e. spyware or other persons stuff). That should do it. Now add your system into your FindMy group to make sure there is nothing hanging on it.
这个答案有帮助吗?
得分 3
2条评论:
So basically what you are saying is that i can do the "upgrade" as long as im careful and swap the touchid button for one paired to the new mobo ?
完成的
@denuwu - Yes! The button is paired with the logic board!
完成的
添加一条评论
Only Apple can pair Touch ID, so you will need to manually transfer the Touch ID sensor.
这个答案有帮助吗?
得分 1
2条评论:
Im aware of that as i said the motherboard that i plan to buy comes with one so that shouldnt be an issue question is are there any other things i need to worry about or is touchid my only concern ?
完成的
@denuwu As far as I know, that is the only one.
完成的
添加一条评论
添加你的答案
Denuwu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 89
