跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
239 个问题 查看全部
iPhone SE 2020, restarting every 180s because of tg0b, board defect?
Hello Guys, i need help. I have an iPhone SE 2020, replaced screen (by me) which is now kernel panicking and restarting every 180s (has nothing to do with the kernel panicking, screen replacement was done now a year ago). It has no obvious pry damage, the mosfet by the battery connector is still in place and not moveable. With both the OEM Battery and a new 3rd party one the kernel panic keeps happening as well as the 0% battery charge thing. In the logs "missing tg0b" is stated. When starting without the dock and front camera flex attached the logs state "missing tg0b and mic1", so i suppose its a board issue? Any tips?
Update (07/26/2022)
The battery connector
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
One of the data pins looks to be pushed into the plastic but I cannot be certain. The measurements you took are okay.
完成的
添加一条评论
3个答案
最有帮助的答案
This does sound like a battery data problem. The first thing to check would be the battery connector as they are known to be problematic on this model. Check the pins have not been pushed into the plastic, if they have you will need to pry them out. The next step would be measuring the pins with a multimeter in diode mode. Also there are two fetts near the battery connector not just one.
这个答案有帮助吗?
得分 1
1条评论:
i measured the pins and got the following readings: GND for GND and 418 for the 2 big pads on the other side as well as 689 for the data pins. Ill post in another comment a picture of the connector
完成的
添加一条评论
Hi Benjemiah,
The error code refers to Temperature monitoring chip on the motherboard stopped working due to no feedback from the temperature sensor it has gone to fail safe mode (restart for every 3 mins)
这个答案有帮助吗?
得分 0
1条评论:
So it is not a Battery SWI Problem? How can it be fixed?
完成的
添加一条评论
See this youtube link: https://www.youtube.com/watch?v=GSH2Y-Sp...
This will show in detail the circuit board issue
This is reference to the Panic restart every three minutes with reference to Mic1 not being found
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
benjemiah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 346
