跳转到主内容
加入维修社区 - 创建账户
Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
Screen & battery not working.
I purchased battery, screen, & touch gasket from Ifixit. I followed the tutorials to change the battery, but I broke the original screen. Watch continued to work fine with the cracked screen, but I decided to replace the screen and gasket. After 1st attempt I had black screen but haptics worked. After trying to fix the black screen, I now have no screen, no haptics, & no response from a reset or charging. Any ideas? I just ordered new flex cables to see if that’s a fix. I also noticed the center connector on the screen moves a little when I try to plug in the cable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You maybe digging a deeper hole here ;-{
The cable assembly requires desoldering from the SIP package! Do you have a Hot Air rework station?
这个答案有帮助吗?
得分 0
3条评论:
I do know how to solder and desolder, so hopefully it’s still possible. I can’t figure out why the haptics stopped working tho!
完成的
@amberds - You have access to a Hot Air rework station as that is what you need a simple pencil soldering iron won't work here.
This is getting worse if haptic engine is damaged too ;-{
完成的
I actually think something is going on with the battery. The cables don’t have any bends, tears, or bare spots, and they plug into the screen easily. The screen is brand new. I guess we’ll see.
完成的
添加一条评论
添加你的答案
Amber 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 142
