跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
Where are the hinge screws?
I have not worked on a DS before, let's get this out of the way
I was given a black ds lite where the hinges are fine, but are looser then my old DS lite I sold for a PSP
I need to know where to find the hinge screws so it doesn't snap like they do, which i see on eBay
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Nick, Merry Christmas....:-) take a look on here and see if it helps.
完成的
添加一条评论
2个答案
已选择的解决方案
Merry Christmas nick! Have a close look at the right hinge as you look at the open console.. The right side is the one that usually cracks causing the loose effect, it's only 2-3mm wide on the top case portion, sometimes you can see the crack but the case stays together anyway. I lived with mine like that for a while. Putting a clear Perspex case protector on gave it a bit of added stiffness but if it is cracked in the long term you'll need to replace the top case to replace the cracked portion. Seen a few posts about epoxy fix but..
这个答案有帮助吗?
得分 3
添加一条评论
Try one of the great iFixit guides here
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 635
