跳转到主内容
Released in Sept, 2018 by OPPO
My phone is not turning on
Before 1 month ago my realme c1 phone was suddenly turned off then I go to for repair they changed the folder and it was working after 15 days it happened again and my phone has been turned off while charging time.
Since then my phone is still not on.
Can you help me।
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
2个答案
最有帮助的答案
Try to press and hold the power button for few minutes and repeat this process and check if its works.
这个答案有帮助吗?
得分 2
添加一条评论
If there is lint in the charge port, the cable can't seat properly and this can prevent it from charging at all. VERY CAREFULLY use a pin or needle to check that the phone's charge port is clean.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
THIS IS PAVAN KASHYAP 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 42
总计 1,417
