跳转到主内容
Repair guides and support for weed whackers, also known as string trimmers, weed eaters, edge trimmers or line trimmers.
86 个问题 查看全部
How do I remove this trimmer head? Shakespeare Push-N-Load 3-Blade
The trimmer itself is a Stihl FS 40C, I cannot get the head to stop spinning in order to twist the Shakespeare head off of the threads. I can provide any additional information as needed. Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Reviewed any videos like this one(?); https://www.youtube.com/watch?v=JFYextYI...
完成的
添加一条评论
1个答案
已选择的解决方案
With the trimmer head on the ground, on top of the gearbox where the head is, is a hole. You put a bar in and turn the head until the bar locates in a groove inside. Or even a screwdriver will do. This locks the shaft from moving so you can unscrew the head. I think it’s a left hand thread if I remember correctly.
这个答案有帮助吗?
得分 2
2条评论:
man i was stuck...with the same problem...u got it figured out for me...i knew there was a hole somewhere...but reading ur response got me to look again...and there it was lol...Preesh
完成的
@ashleymcke89493 Glad I could help. 👍
完成的
添加一条评论
添加你的答案
Tyler 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 48
过去 30 天: 142
总计 1,439
