My MacBook Pro won't shutdown
my mid 2012 MacBook pro needs a smc reset because the controls are not working right but the power button seems not be working so i can't shutdown my mac do to a smc reset
Update (07/15/2022)
Nevermind i figured it out
What ended up happening? If there is a solution you found elsewhere, or that you found on your own, you should post it here for anyone who might be having the same issue.
由 Jacob Mehnert 完成的
@superfixer334 , yea, it would be good to find out what you did. Just in case someone else runs into the same issue.
由 Kris Rodriguez 完成的
@krisrodriguez - I'm guessing Evan press and held the power button down or just pulled the battery connection.
由 Dan 完成的
@danj , probably, that's a good guess :)
