跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
204 个问题 查看全部
MacBook won't turn on or charge after replacing keyboard and battery
After replacing the keyboard and battery, a1990 does not show signs of life and does not respond to turning on or charging.
I tried:
1. Reset SMC & NVRAM - no signs of life.
2. I tried to restore a1990 using MB16m1 DFU- a message appeared on "Cannot Use ThunderBolt Accessory", on MB16m1, but a1990 did not switch to the DFU mode.
Any ideas what's going on?
Is it possible to consider "Cannot Use ThunderBolt Accessory" a sign of life and performance a1990?
Will a1990 run on mains with the battery disconnected?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Why did you replace the upper case (keyboard & battery assembly)?
And was the system working before?
完成的
In the basic state before the repair, everything worked (except for the sticking of the buttons and the low battery life), after the repair the system did not turn on.
there was no topcase assembly in my city, and it seemed not economically feasible, I bought a macbook m1 pro 16, I wanted to restore a1990 on a budget
完成的
Did you transfer the Power button over to the new uppercase? The power button of your logic board must be transferred as well.
完成的
添加一条评论
1个答案
已选择的解决方案
Strip it again and check you haven’t pulled a board connector. Solder connections can sometimes break if handled incorrectly. You might need a microscope. Or the parts you fitted aren’t compatible.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Роман Абрамов 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 8
总计 128
