Is there any way to upgarde it's RAM , Storage?
As I know most of it just solded to the motherboard but is it posible to remove and upgarde ?
Hi
Yes it’s possible but there is some things you should know first
1.this requires ALOT of soldering experience and this process is extremely difficult
2.your motherboards circuit may need modifications in order for this to work as different configurations may need different components in different places
3.you will need to look up the laptops max ram if it is known
Hopefully this helps
这个答案有帮助吗?
I'm sorry, but no. At least not in any practical sense.
These were intended as light-weight and durable, yet inexpensive units, a such the various components are soldered to the main board. The units themselves were not designed nor intended to be upgraded.
However, you can purchase USB connected portable external SSD components to increase storage capacity.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 39
总计 455
