跳转到主内容
7th Gen Amazon Fire HD Tablet was released June 2017. It has since been discontinued and replaced by the current Fire iteration.
4 个问题 查看全部
Device not charging after 1%
I plug in my device using several chargers to test if it's the charger is the problem but it won't work. After I plug it in the battery sign show that it's charging and after it turns on at one percent its not charging when it's on and I can't stop it from turning on automatically
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Please answer
完成的
sounds like u have to take the battery out and put it back it sometimes tablets do this do to their poor design
完成的
or could be the cord is malfunction that happens to do to another poor design
完成的
The battery cannot be removed
完成的
how does it work if there's no way to remove the battery that means there's no way to put it in either? your logic man
完成的
添加一条评论
1个答案
If it charges in the beginning and you do not move it then there is no reason to think that it is a bad cable or connector.
The most likely issue is a spent battery. See if you can find a battery test app and run that to see what the health of the battery is.
这个答案有帮助吗?
得分 0
评论:
Ok thak you very much
完成的
how about a rating if it helped?
完成的
添加一条评论
添加你的答案
Millie lee 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 5
过去的30天: 18
总计 66
