3D printer blue screen
Built printer, then it turned on. Leveled the plate to the print Nozzle with a piece of paper. I printed 2 test models then a 5 hour model. All 3 models we fine. Then turned off printer. The next day I turned the printer on and only got a Blue screen.
was the printer bumped at all?
由 Cameron Smith 完成的
No.
I did a puzzle tube print which took 5 hrs, when it was done I turned the printer off. The next day when it turned it on it had the blue screen.
由 Frank Lovash 完成的
ok, check the connections maybe. there is one on the back of the LCD and another inside the CPU
由 Cameron Smith 完成的
Are you using octoprint or an SD card to print your models? Try using octoprint instead on an SD card, I accidently inserted the wrong SD card and it corrupted the firmware. Try re-flashing the firmware , that usually did the trick the few times it happened to me. On one occasion the LCD connector was loose. good luck.
由 Luis 完成的
I checked all the connections before hand and then went through a lot of different things that others have said to do., nothing helped.
I just don't know what else it could be. It is brand NEW. I just got it and did 1 print job, turned it off after it was finished, next morning turn it on and got the blue screen.
由 Frank Lovash 完成的
显示更多的5条评论
