跳转到主内容
加入维修社区 - 创建账户
Scientific Casio Calculator released August 2000. Identified by the model name FX-115MS
How do I fix my transparent solar calculator
I know it sounds fake but those things are real, i couldnt find any pictures of it in the options and mine is kinda broken.
6 works but the other keys don't, i went outside coz i figured that maybe it needed sunlight but it still didnt work. What do i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Tried disassembling it and cleaning debris collecting between the membrane keypads and circuit board? The carbon film on membrane pads may be worn down and unable to connect circuit lines when pressed onto the board. Other issues may be worn out electronics or damage wiring. If unable to resurrect this calculator then its time to replace it.
完成的
添加一条评论
1个答案
The solar cell charges a battery, they don't last forever so I d open it and see if I could find a replacement battery for it. If you perhaps dropped it there could be just a loose connection so look for anything obvious. Not your device but possibly helpful answer referencing a solar powered calculator repair is here. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TheGuyWhoAsked 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 29
总计 704
