跳转到主内容
Whirlpool WTW4816FW or the Maytag Centennial washer MVWC415EW2.
9 个问题 查看全部
not draining and spinning
tp load Maytag does not drain and spin, but if I manually turn the dial to spin cycle, it drains and spins perfectly. Dial need cleaned?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi,
What is the model number of the washer?
完成的
Sorry I forgot yesterday. It's a Maytag Performa, model PAV2300AWW rev12. thanks Darrin
完成的
I know this has probably been repaired or replaced by now, but I recently had this problem with a Kenmore 110 which I believe is the same machine. I replace the start capacitor which is located on the motor at the bottom of the machine and that solved the problem.
Video can be found here.
https://www.youtube.com/watch?v=RNcTX3YY...
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Sounds like the timer (part #WP21001522) may be the problem. Either a worn contact operating cam or a faulty (dirty?) contact.
Unfortunately, they cannot be repaired, they have to be replaced. Search online using the part number only to find suppliers that suit you
Do not attempt to open the timer to fix it as you will have cams and contacts going everywhere once the case is opened.
You could try disconnecting the power from the machine and then accessing the timer and liberally spraying some contact cleaner (example only - there are others), in through any openings in the timer case, allowing it to fully dry (read directions on can) and then check if it now works OK. Do not use "regular" WD-40 as this leaves residues which may cause problems.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Darrin Fitzpatrick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 253
