大众汽车的修理和支持指南。
242 个问题 查看全部
How to remove the egr valve on my 1998 vw gti vr6
The EGR VALVE on my 1998 golf gti vr6 is located in front of the engine and I am trying to find a step by step instructions on how to remove it so I can clean it.Please help.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Is that the same one as in Where is the EGR VALVE(Pictures,Please) located in 1998 golf gti vr6 Did you check those links? What do you want to clean on your EGR valve?
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
The EGR valve on your VW is also known as Kombi-Valve or Secondary Air Injection Valve. In general the EGR valve is not a serviceable part. As you can see from the images on your other question, it is a a sealed component and does not really allow you any access to the working parts.The only thing that you can try and do is to clean the passages from excessive carbon buildup. You would do that with some carb cleaner.
这个答案有帮助吗?
按维修分数 2
添加一条评论
添加你的答案
Lee 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 5
过去的30天: 9
总计 1,187
