All of the lights are on, but the computer doesn't post.
As above. I replaced the display cable before this happened, and I tried turning the computer on and the power light, disk light, caps lock light, and WiFi light stayed on, but no signs of life. The HDD didn't spin, the fans stayed off, and not even the power button responded to any input. I have heard that the onboard RAM (soldered to the mobo) might be bad, but as of right now I have no way to test it.
5条评论
You say if it was working before you replaced the display cable.
由 mike 完成的
@aactech I did replace the display cable, but I know that is not the issue here. I have tried using HDMI output with no success.
由 Jeb 完成的
Hi @dumbin8er
When was it last working and what happened just before it stopped working?
由 mike 完成的
@aactech I was replacing the cable. When I put it back together I noticed it wouldnt post. (This was several months ago btw)
由 Jeb 完成的
@dumbin8er Must be something to do with how you connected the cable unless you disturbed something else while doing the replacement. Yes it is hard to recall several months back! I would just try redoing it again. Photos and notes sometimes help when doing repairs.
由 mike 完成的
