跳转到主内容
Apple 2020年的顶级智能手机。iPhone12 Pro Max于10月13日发布并于11月13日发布,配备6.7英寸OLED显示屏,带LiDAR的三重后置摄像头系统和5G连接。iPhone 11的后继产品。 专业版
108 个问题 查看全部
Face ID and screen brightness dimmed! Ambient light sensor replacement
Solved! I don’t have a simple solution but try leaving it in rice for a week or two.
In my case it was sunscreen residue that came inside the headphone speaker, so i had to pour alcohol inside multiple times (be careful and don’t try this unless you’ve lost hope) aswell as drying it in rice for weeks
My iPhone screen suddenly went dark which I initially thought was just battery juice running out. However, I noticed it actually still was on while using it in a darker room. I could barley see anything so I tried to restart it.
When booting up, it did light up normally but it dropped brightness immediately after. Also, An error message ”Unable to start up Face ID” appeared.
i tried restoring the phone with iTunes and stopped auto brightness and Truetone from settings, without any improvements.
I believe this has to do with the ambient light sensor, because the problem doesn’t seem to be a software issue and it’s affecting screen auto brightness function and Face ID.
I have experience replacing bad batteries and broken iPhone screens but never had to change a sensor component. I read that changing them will lead to iPhone not recognising the new component and losing Face ID. I also read about this recognition problem being solved back when apple released IOS 12. If not, is it possible to reprogram the new sensor? Also, where can I buy this part from?
P.S: Apple fixes it free of charge for apple care and warranty holders but I don’t have that option so it’s going to be a pricey fix with apple. I would rather do it myself if possible.
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
9个答案
最有帮助的答案
I had this same issue and tried everything I read online to fix it with no luck. Then I was messing with some settings and tried the display zoom setting and for some reason that worked. I just put it back to standard and was able to control by brightness again. unfortunately it does not fix the face id problem.
这个答案有帮助吗?
得分 16
15条评论:
This worked for me, too! Thank you!
完成的
This works as well! I popped the wire for the face id and sensor during a screen replacement and needed a temporary fix until the replacement part arrived. Thanks!!
完成的
It worked! Changing display zoom setting fixed the abrupt dim problem. I can't thank you enough.
完成的
worked for me!!!! tysm!!!!
完成的
You are my savior, thank you so much. Face ID and Auto brightness not working can live with it.
完成的
显示更多的10条评论
添加一条评论
If you did a factory reset and then disabled auto brightness but the problem persists then the problem isn't in software and isn't with the ambient light sensor since disabling auto brightness would have effectively ignored or overridden a bad ALS. You have a bad display and/or a bad logic board.
这个答案有帮助吗?
得分 2
1条评论:
Try resetting the iPhone and updating it from a Mac. I think they released an update that fixes dark screens with broken ambient sensors. This worked for me.
完成的
添加一条评论
Try a screen replacement from Apple's self-service repair program, it is the only way you can get Face ID back yourself.
这个答案有帮助吗?
得分 1
添加一条评论
This is a common issue on this serie, mosty happen after water damage but can be also only from small raining etc. The light sensor flex get oxidacion and its disabled. Typic symptopms is device boot with normal brightness and instantly when boot on home screen the brightness come down. Easy way to fix is replace the sensor flex - you will lose face id and portrait mode on selfie camera, but brightnes will be normal again. Or you can solder the original sensors (without mic to another flex, will save the face id and portrait. When is the sensor self damage can can restore the original value from device and Programmed for example with JC Programmer. But 95% sensor self is ok. You can also try clean the flex with 90%+ alkohol or reflow with some good flux on 220°C, sometimes the flux remove oxidacion.
这个答案有帮助吗?
得分 1
2条评论:
This is useful to know, but seeing as this seems to be a common issue, why is Apple not taking accountability for a flawed product? My iPhone 12 Pro Max has just started doing this as as usual, it is 7 months past its warranty date.
I don't see why Apple customers should be paying a penny or spending their own time trying to fix things that Apple has not made properly.
完成的
Problem is, there must be somehow hole to the ear speaker and mic sound can flow there. Most time is this hole only the one way for water go in the phone. And the sensor flex is first component what can be easy damage.
完成的
添加一条评论
Hello Alen.
You would be correct, the brightness and Face ID failure are due to replacing them, Apple forced them to not work if they are non genuine and not paired, unfortunately I don’t know of any device that can re-pair the parts. The only thing really is too update it and hope that Apple has fixed it. I hope your phone will be able to be fixed.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem. I changed the screen and it didn't work. Is there any other solution?
They told me on the mac store that if the change of screen didn't solve it, I should buy a new device...
这个答案有帮助吗?
得分 0
1条评论:
I got it diagnosed by apple who said the light amber sensor and the magnetometer are damaged. They said it was probably caused by water or possibly moisture. I recommend you start with getting yours looked at (you can do it online using apple care app)
I then left it for repair in Mediamarkt and they are currently looking at it. They said it's most likely not recoverable but since i had insurance that covers it i only will have to pay a small amount to get a new one.
Did you get your replacement screen from Apple and do their screens includes new sensors or did you have to move the sensors to the new screen?
完成的
添加一条评论
Hi! I had this problem too. So i pressed volume up button, release it, then did the same with the volume down one, then pressed the side button and hold it until it shows me the slide thing on screen. You need to slide and close your phone.Then waited 5 sec, started it and it crashed,did the whole thing again and it worked:)
这个答案有帮助吗?
得分 0
添加一条评论
Did you find problem ? I had same one whit my Iphone 12.
这个答案有帮助吗?
得分 0
添加一条评论
I think that is hardware issue. Most of that cases happens after water or moister on Front ear-speaker flex have ALS,Proxymity senser that have imp role on face id too.You have to swap the ALS to another working flex.I also face same issues and fixed on 12 pro max you can check yours like that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alan.bakr22 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 39
过去 30 天: 175
总计 9,357
