跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
I tried removing lock-screen pin. Now phone doesn't turn on? Help!
Hi,
I tried using software (I think FonePaw or such) to unlock my old Galaxy S5 (SM-G900T1) to access the old photos and videos. But it got stuck in between and now the phone doesn't turn on, except when I press the 3 buttons (power + home + down sound). And when it does, it simply shows (the image below) and then quickly shuts off every time.
Please tell there's a way to fix this, and also save my pictures and videos!
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
A couple of solutions for your error message:
  1. A youtube video here
  2. From Phone Paw, since that's what you used? here hope one of them work. I take it you do not remember your account and password for the phone? Try looking for saved passwords in your pc, firefox, settings saved logins for example.
  3. On a samsung you can also follow the advice here
# If none of those work, give a holler, usually there's some other way to do things on Android, the problem's finding them.
这个答案有帮助吗?
得分 1
3条评论:
It doesn't look like I can get into Download Mode to do it. Holding the 3 buttons only gets the response (in the image) and then the phone shuts down. Is there another way I can do it? Thanks
完成的
When you connect it to your pc, is it recognized? And have you tried accessing the phone this way?
完成的
@bradmcgash Do you have access to a pc?
完成的
添加一条评论
添加你的答案
Brad G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 50
