跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
How can I replace the rear display housing, part number 922-7898?
i have a macbook 13" unibody with a damaged rear display housing (the part with the Apple logo). Is it easy to replace, and would the accidental damage to it it be covered under Apple Care?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
No it is probably not covered by Apple Care.
It's not easy at all. First you'd need to find a replacement one, which probably means buying an entire display assembly, then you'd need to take of the glass by melting the glue all around it with a heat gun, which is risky, you could damage the rubber or the lcd itself.
if you want to make your own opinion, here is the guide for a unibody macbook : MacBook Unibody Model A1278 LCD Panel Replacement
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
simon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 512
