跳转到主内容
加入维修社区 - 创建账户
首次生产日期:2011 年 12 月 20 英寸 SyncMaster 显示器,分辨率为 1600 x 900。它还具备 Magic Angle(灵视角度)和 Magic Tune(灵调校)等选项。
HDMI Port repair & Replacement
No display an image into the monitor by using an HDMI port
how do i repair & replacement plz help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
How do you know it is the monitor and not the computer that is at fault?
由完成的
love kesh try all the other input sources and see if those work. Your monitor is a Samsung 20 inch monitor S20B300B?
由完成的
添加一条评论
1个答案
最有帮助的答案
  1. Make sure your computer can actually display the image. If you are using a custom PC and have a discrete GPU, make sure you are plugging it into the GPU instead of the motherboard. If that doesn't work and you have an iGPU (integrated GPU), try plugging the HDMI into the motherboard.
  2. If none of the above works, check your HDMI pins. Look into the port (on the PC and the display) to make sure that none of the pins are broken. If a port on the PC is broken, try using (if you have) the other ones. Most PCs come with multiple HDMI ports.
  3. Make sure that everything is plugged in, and test the display with another computer.
  4. If it still doesn't work, you may need to get your monitor or PC (depending on which is broken) repaired/replaced.
If there is anything I missed in this answer, please let me know!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
love kesh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 41
总计 893
