跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
548 个问题 查看全部
should I clean my fans manually or replace them?
my fans are dusty and i am wondering if i should clean them myself or just replace them entirely?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Cleaning is quite easy! Get a small soft pain brush and a can of can'ed air so you can blow out the dust & debris.
I would follow these two guides as its better if you remove them:
Carefully scrub the blades as well as the heatsink fin areas. I blow the air outward across the fins and a few short blasts on the fans. You don't want to spin them up, I often carefully wedge a toothpick to hold the blades from moving. Don't for get the give the logic board a quick wipe as well with the brush and then blow off what you've loosened up.
MacBook Pro 15" Retina Display Mid 2012 右风扇更换图片
指南
MacBook Pro 15" Retina 显示屏 2012 中期 右风扇更换
难度:
中等
45 minutes
MacBook Pro 15" Retina Display Mid 2012 左侧风扇图片
指南
MacBook Pro 15" Retina 显示屏 2012 中期 左侧风扇更换
难度:
中等
20 minutes - 1 hour
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the help
完成的
添加一条评论
添加你的答案
Jake Pfaff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 62
