跳转到主内容
Apple's mainstream 2021 iPhone was released on September 24th and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 12.
50 个问题 查看全部
wifi Greyed out after screen replacement
Do you know why Wifi is disabled or Greyout after new screen replacement of iPhone 13
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It is unusual that WiFi would be greyed out without some sort of a hardware fault. However, if the issue did not exist prior to the display replacement, I would reseat all the connectors. As best I can tell the iPhone 13 does have some antenna related connectors in the vicinity of the connector for display sensors. I would also have a look and make sure it didn't seem as though any liquid was in the phone anywhere.
Otherwise, I might wonder if there was some underlying damage, which was worsened by the repair (not through any particular fault of your, just normal repair related strain) , or pry related damage from removing the screen. I don't have any documentation for the iPhone 13 series other than an unlabelled board view, so not sure what sort of components might be in the area of those display connectors.
这个答案有帮助吗?
得分 2
添加一条评论
hello iRepairMan,
this is impossible, greyout WiFi was before, just You didn't check. There is a possibility of blocking by a faulty parameter, but it should also apply to bluetooth. Check it out too. Most often, similar problems come after falls and crashes, does this phone have a broken back and screen? I guess so. In this case, to eliminate the probability of damaging the interposer, desolder the sandwich and check the connections (preferably in the test frame and start the phone).
- best regards and fingers crossing
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
iRepairMan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 62
总计 574
