跳转到主内容
Vavle 公司于 2022 年 2 月 25 日发布的游戏掌机。
244 个问题 查看全部
ZIF connector locking tab broken - Any fixes?
So in an attempt to replace the screen on a damaged deck I somehow managed to knock off the locking tab for the display zif connector on the motherboard. The connector still sits in the socket but the display does not work. I assume the issue here is the missing locking tab causing issues with connection, is there any fix for this or is the motherboard now a paperweight?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
So the short and skinny of it is that there are ways to fix a broken ZIF Connector. However, they're not particularly easy to accomplish. There is a similar question that was posted here that has a solution and gives you some options for repair. My suggestion is replacing the port itself. There is a video guide that shows you how to replace the port here, but it requires micro soldering skills.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rosie Turner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 33
总计 896
