跳转到主内容
Do Dell OEM SSDs sold later include the M.2 2280 adapter w/ 2230 SSDs
I have an Inspiron 3670 which checks a lot of boxes, except two:
  • 1TB WD Blue
  • 16GB Optane module
Yep, someone really bought it with an i5 and crippled it with an Intel Optane module :(*. I tried it, and I'm not impressed with the performance to the point I want to install a proper SSD.
*Before someone gets on my case for not liking Optane for much of anything, I UNDERSTAND it helps lower end machines with i3's and Pentiums with spinning rust for less. However, this one has the i5-8400 with 8GB of RAM, so it's hampering the performance enough I can immediately tell it's not a good fit. If it helps your i3 laptop, use it -- but on this machine I tried to like it but it's still too slow vs. what the HW can do.
If you see Core i5+, this just means you have a standard i5 with Optane. It means nothing; same IGP as a non + system.
It doesn't make a performance difference, so I want to replace it with a NVMe boot SSD and retain the 1TB drive for storage. I do see I can get a drive direct from Dell for it with the M.2 2230 form factor, but I do not know if these come with the needed adapter -- I just cannot find them in the US without buying a used SSD, which tends to cost as much as an open market 2280 from TEAMGROUP. However, I can import one... for $44+33+Customs cost*. Not happening.
*As I am in the US, it takes a lot for customs to bill you for personal use. However, it still happens.
Does Dell sell this adapter piecemeal if it doesn't come with the drive, or do I need to buy a used SSD to get it if I cannot find the required 2280 adapter to replace the Optane cache?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Technically I don't need any adapters if I move this to 2230 vs 2280 -- I just need to move the screw :-). This is the kind of design we need for right to repair, and while I much favor HP in most ways (especially commercial, Dell has cheapened the machines out a bit too much for my liking but the price was right for a i5-8400) this kind of forward thinking design needs to be rewarded.
Maybe someone gets one like me and tries to like Optane. Maybe they realize it's pointless on a good configuration as well. This makes it really easy to throw the Optane out for NVMe boot storage.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 135
