跳转到主内容
Repair guides and documentation for the Google Pixel 5a with 5G smartphone. Released in August 2021.
13 个问题 查看全部
Need help determining if the screen or motherboard is the problem
So my friend purchased a pixel 5a for parts on ebay. Screen looked good, No cracks or OLED broken. He sent me his phone to fix and it arrived and I did the swap of the screen. Sadly the screen does not light up but I can hear the phone do things. I am wondering if the screen is at fault or if I possibly damaged the Motherboard since I was unable to power off the device cause the original screen did not work. Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
My phone is having the same issue, the screen is black and unresponsive, but the phone vibrates when I touch the fingerprint scanner or hold the power button. I got a replacement screen on ifixit and replaced it with no problems, but nothing changed and the new screen won’t turn on either.
完成的
添加一条评论
1个答案
最有帮助的答案
Just so I am clear that I am I am interpreting the issue correctly. Your friend had a phone with a broken screen, bought a phone from eBay to use the screen from? You swapped the screens, doesn't get an image with the new screen? Is that right?
Regardless, I think checking to see if the original display still works would be a good next step. Unless it was also having the same original symptoms. If the original display still works. It sounds more likely that it's an issue with the replacement screen. If not, or the new display didn't resolve the initial issue, I would inspect the connector on the phone and any components around it. See if anything looks amiss. If you can't tell, feel free to upload some photos to your original question. If the new display was harvested from a "for parts" phone, anything could have been wrong with it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Dudefoxlive 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 66
总计 709
