跳转到主内容
The OnePlus 8T is an Android smartphone manufactured by OnePlus, released on 16 October 2020.
15 个问题 查看全部
fingerprint sensor not working after oem screen replacement
I paid a repair shop to replace the front screen and rear glass . He used brand new oem parts , however , the fingerprint scanner doesn't scan . it lights up , but does not do anything but vibrate with touch . when trying to register a new fingerprint , it says please clean the glass . The phone has been factory reset several times , hoping it would fix it. I'm thinking it needs recalibrated or something ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did you try clearing the cache? Down at the bottom of this page this is suggested as a possible fix.
完成的
Try to get the finger print sensor checked just in case it was damaged in the process
完成的
添加一条评论
1个答案
最有帮助的答案
The reason is because of Android 12. Flash your phone after taking backup so that it falls back to Android 11. Then set up your finger print and upgrade to Android 12
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Doug A 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 650
