跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
brightness drops to 75% randomly
hello, i have replaced iPhones xs screen bought from ifixit (the OLED Packeg) replacement smooth and fine but i've noticed that time to time brightness off the display drops to around 75% (the top 25% won't do anything) and stays like that, seems pretty low and some time hard to see under sunny environments, reboot won't fix the issue but after sometime it fixes it self, is this a know issue? (BTW this 2nd screen replacement of the device first was done by Thirdparty and was working fine in these regales but had other issue which to me was a bad panel used by the shop even had bad fitting issues) this panel does not have such issue 3D touch is working fine too which wasn't working before. any idea what is causing this behaviour? BTW auto brightness works fine when this issue is not present.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
How hot is the phone?
完成的
not hot normal temperature @areeve
完成的
that is what causing but phone is not overheating is slightly worm it use to get even hotter before and never had this issue even is display replaced.
完成的
添加一条评论
1个答案
已选择的解决方案
Screen dimming is part of the overheat protection, it is overheating or at least it thinks it is.
这个答案有帮助吗?
得分 1
2条评论:
i will do the test again to make sure if this is causing, then after it turns to normal temperature it should go back to normal isn't it? then why doesn't it go back to normal?
完成的
@rokieride It doesn't think it has returned to normal temperature.
完成的
添加一条评论
添加你的答案
Rokie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 69
