跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
421 个问题 查看全部
MacBook Air "Core i5" 1.6 13" (Early 2015) A1466 (EMC 2925) Lid Sensor
Hello,
I'm working on a logic board of the A1466 (EMC 2925) and I'd like to know the exact position of the lid sensor. Since the screen has been completely ripped off (lol) before I got it, I can't seem to force it to boot to an external monitor. (The solution would have been to close the lid, simply).
The logic board has been isolated from the rest, to the bare minimum, and the fan is spinning. I think the board works, but can't really tell until I can properly what is going on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The sensor is located on the I/O board on the Uppercase side (hidden)
You'll need a rare earth magnet to slide across the upper case along the edge when the sensor sits to enable it (emulating a closed lid)
Here's the needed display assembly to replace it if the original one is to messed up MacBook Air 13" (Mid 2013-2017) Display Assembly and the guide to replace it MacBook Air 13" Early 2017 Display Assembly Replacement
MacBook Air 13" (Mid 2013-2017) Display Assembly图片
产品
$314.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
cold stuffs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 182
