跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly information for the Samsung Galaxy Buds Pro wireless earbuds.
right earbud blocking airflow, casues pressure buildup inside of ear
I must have blocked the air vent in my right galaxy bud pro as it now causes an airtight seal within my ear when wearing it. I've attempted unblocking it by using a fine brush with some isopropyl alcohol but was unsuccesful. How could I attempt to unblock it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
@miguelmoretti try some isopropyl alcohol and a few puffs of compressed air. Use something like air-in-a-can that you would use as a keyboard duster. Available in most department stores. Alternatively, you could use some suction from a small, yet strong vacuum cleaner or similar device (like a big 60ml syringe attached to a small hose etc.). Those things love to collect cerumen (earwax) If that does not work you will most likely have to disassemble them (no fun at all) and clean it from the inside out. Samsung Galaxy Buds Pro Teardown - iFixit
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem with my right earbud. What I did was get a Q-tip and isopropyl alcohol and really worked it into the grille on top and the small one inside the bud. I took the rubber earpiece off and blew into it gently, then sucked gently. Doing that twice fixed it for me. You won't feel yourself losing pressure, but it definitely worked.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Miguel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 76
总计 3,893
